02-02-2025 04:35 PM
I have a two-wire configuration with a Red Wire = V+ and a Black Wire = Vg. My original thermostat is a Daikin BRC1E73
I have a Gen 3 Learning Thermostat and all indicators, videos and specs said this was Compatible with 2-Wire Configurations. The two wire installation instructions are looking for a Red (RH) and a White (W1) wire connection.
Please help! It's too late to return the Thermostat, and I checked compatibility before we purchased! Thanks.
02-02-2025 10:47 PM
I'm not sure how you checked compatibility but based on the wiring that you have, the Daikin is not compatible with any of the Nest thermostats as it uses a proprietary interface.
