No cooling only heat air coming out
Marcchallita
My thermostat was working fine is summer winter came we atarted using it on heat mode now summer again and when i switch to cool mode it keeps pumping out hot air i tried resetting tk factory settings  and i switched from O to B and turned it back only hot air comes out my tech is saying we meed to change the nest they are not good i dont want to change it i like it how can i fix the issue?
aguilarmateo
Hi Marcchallita,
Sorry to hear the situation that you are experiencing with your Nest thermostat on cooling mode. Help is here!. I have some troubleshooting steps that might help you.
  • 3- If the problem persists our support team can further assist, contact them using this link: Contact Us.
Chris
