07-01-2025 01:39 PM
Our hot water is not working but heating is. The Nest thermostat is not powering on. It seems as though the heat link is not sending any signal to electricity/power to the thermostat for hot water.
We have had an electrician over who has suggested that the heat link requires replacing.
07-02-2025 08:21 AM
I have this same issue. Heating works fine but hot water not sending signal to boost hot water. Electrician has said there's not voltage on the heatlink when sending the hot water request, but there is on heating. Heatlink faulty perhaps.
07-04-2025 02:52 PM
Thanks for reaching out to the community! I understand your Nest Thermostat isn't powering on, and your Heat Link is not supplying power or signal to your hot water system, despite your heating system operating as expected. I appreciate having a technician check it out. No worries, help is here!
To assist you effectively, the team would like to learn more about this situation. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
I look forward to your reply.
Jenniffer
