01-08-2025 01:05 PM
01-08-2025 10:49 PM
Post a picture of the current thermostat here.
I see a C terminal and a spare blue wire. Verify that the blue wire isn't connected to anything at the thermostat. If it is not in use, then you can connect the blue wire to the C terminal on both ends and you'll not need the Nest Power Connector.
01-09-2025 08:51 AM
I will try that, thanks
