11-23-2023 03:27 PM
After several days - and many hours - I have put my old thermostat back on the wall as a cold night approaches and the Nest Thermostat completely failed us. After initial install on a two wire/heat only (R and W) Google told me I had low power and needed a Google Power Adapter which they kindly sent for free. In the meantime the Nest worked fine for a week even though it gave me a N error - low power issue. When I came back to the house (2nd home) with the power adapter I had studied up and realized I just needed to add a C wire. My wiring had a third unused wire. So I connected that to the C 24v screw on my control board and connected the other end to my nest. It worked but was now flashing NO POWER once in a while. In SETTING/EQUIPMENT it gave me a N code - but it connected to internet just fine and I could control heat. When I went to wiring I could see all three connected wires and when I went to power it was moving around between 29v and 32v. All the power settings showed connection. But still the N error and the occasional NO POWER. In the midst of this C wire install - I got low battery warning so changed batteries. I used the app to re-set the wiring configuration. It controlled the heat last night just fine. But as a 2nd home I don't want to find out I had been on battery power and have heat go out when I'm hours away. Trying to remedy this - today I disconnected C wire and installed Google Power Adapter. Then things went kerfluey. It was flashing NO POWER constantly and wouldn't let me do anything. I checked my install and all was correct. When I checked wiring it didn't show red connected. I re-checked my red connections. Still nothing. So I pulled the power adapter and went back to my C wire configuration. (BTW - I turned off system each time and carefully wired all changes.). This time the unit stalled out in STARTING UP. I manually reset by pulling batteries but when replugged in it flashed NO POWER and gave me no controls at all. Beaten, I yanked it and put on the old thermostat, turned system on and set it to a cozy 70 degrees. The furnace roared to life. Extremely underwhelmed with Nest. Can anyone offer advice? I am an above average handy man and can't stomach paying someone to install something so simple as a thermostat.
11-27-2023 08:54 AM
Hi Trystero,
Oh no! I'm sorry to hear about the difficulties you've experienced with the Nest Thermostat installation. Installing a thermostat can sometimes be challenging, especially when dealing with power issues. I understand your frustration, and I hope these suggestions help you resolve the problem with your Nest Thermostat installation.
Let us know how it goes.
