What is Nest Aware? Read more
What is the best method on my internal network to check the online status of my Nest Learning Thermostat 2nd gen? I have a home network monitoring tool that checked and notifies me if a device is unreachable, offline. I would like to add my Nest Ther...
Good Morning, My Google Nest Learning Thermostats just showed up and I realized the wiring for each is different. I believe one is compatible and one I’m not sure about. Each has C W G Y and R cables. The downstairs one has a U1 orange cable and I’m ...
I want to know if my actual wiring thermostat is compatible with nest? Thanks
I have being using 3 Nest Thermostat for last 5 yearsModelDisplay-3.4They are connect using Nest username. As it is connected using nest account and not google account.below link does not have any usage data.https://takeout.google.com/?pli=1How can I...
Can I get my display screen on my learning thermostat to remain on at all times?
My installer has confirmed that our Nest heatlink device has power but does not work. It is just out of warranty. I cannot find replacement parts from Google. I’m told there is a replacement service, but we need heat NOW, the device is apparently eas...
I have a major issue with Google support. I purchased a replacement Nest device via the link provided by one of the team, it was sent out but did not arrive, It's been over a month now and they are not responding to emails with an update, they are br...
@CoolingWizardRecently installed Nest learning thermostat and performed setup on my own. initially didn’t know which O/B setting to set it to so I set the heat pump to O and received no heat. Trouble shooted and set to B and received heat but the the...
I want to set schedules with my nest thermostat. Nest app doesn't allow that. Home app is the only instructions given by Google. However, to setup with home you have the option to scan with QR code. Oh great QR code scans with error. So try the other...
I've seen several posts like this and followed all the suggestions. I'm posting this because my problem still persists. My Nest Learning Thermostat essentially does the opposite of what I want. So I turned off auto schedule and eventually all other s...
User | Count |
14 | |
11 | |
8 | |
7 | |
4 |
