Power Connector installation
Silvasiembra
I am having a difficult time trying to connect the nest power connector using the attached  Schematic.  How do I know what wires to attach To the connectors?  What color is a common wire? Please advise
SoriaD_
Hello Silvasiembra,
Thanks for reaching out to our community! I'm happy to assist you with your Nest Power Connector installation.
You can find information about the installation process on this page. Nest Power Connector installation can vary depending on your specific HVAC system.
If the instructions seem complex, we recommend considering a Nest Pro installation. A Nest Pro can simplify the process.
Of course, if you need further assistance with the installation, feel free to reply to this post. I'm happy to help!
Douglas
Hi Sofia. I ended up connecting an unused blue wire to the common on the HVAC UNIT.
SoriaD_
Hello Silvasiembra,
Thanks for your reply! I'm happy to help you further.
You're right, that's the typical connection location within the HVAC unit. However, there can be variations depending on your specific system. Because safety is our top priority, we recommended a Nest Pro but I'm glad to hear you've already connected the device successfully!
Of course, if you need any further assistance with your thermostat, feel free to reply to this post. I'm always happy to help!
Douglas
