12-11-2022 08:02 AM
I need a help, I have alrady two years google nest 3rd generation and it works well in the first floor, I wanted to solve controled heating also in second floor so I have ordered from amazon google nest heating sensor, but than I found out that it does not work in Czech Republic :-D, I have conected my current thermostat to the gas heater threw heatling, would it help if would buy second google nest thermostat and connect it there? Problem is that I don´t have wires for thermostat upstairs. But I need to resolve it somehow, otherwise I will always have too cold upastairs or too cold.
maybe google nest e can connect to the current heatling wireless and can be charged by usb?
I am not sure about that
Thanks Tomas
12-15-2022 03:15 PM
Hi Palach87,
Thanks for posting.
The Nest Thermostat needs wires to be connected to it to control the temperature. You can reach out to a Nest Pro technician to discuss your options to have heating control without wiring available.
Mel
12-19-2022 10:34 AM
I wanted to check in and see if you managed to see Mel's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
12-20-2022 12:28 PM
