03-30-2022 02:29 AM
My Heatlink unit is destroyed by a power surge, but the circular dial unit is fine.
Where can I buy a replacement Heatlink unit?
Thanks
03-30-2022 05:57 AM - edited 03-30-2022 05:59 AM
Ebay is your best bet.
Make 100% the seller can prove to you it is working, and they show everything up and running to you. Sellers with USB leads plugged into the USB port, stay away from them.
Should you not be able to locate one, I do have some, but see how you get on.
Where are you located?
04-04-2022 06:34 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
03-31-2022 04:20 AM
Hey @DebTownend,
You won't find a Heat Link sold separately, perhaps only at third party retailers. However you might get a replacement for it. Have you tried contacting Google Nest support?
04-02-2022 05:41 AM
Hi, I wanted to check in. Do you need any further assistance? If so, make sure to let me know.
