09-30-2021 10:49 AM
Can’t use my heating system because there’s no power to either the heat link or the nest thermostat. Checked all troubleshooting suggestions with no success. . My installer says it’s a faulty heat link It’s just over a year old. I’m serious thinking of a bog standard Worcester room stat. If I can’t resolve this quickly
10-29-2021 05:27 AM
Hello @Geronimo,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones are present in the setup?
Cristian
11-01-2021 03:50 AM
Thank you Christian C
I have been sent a new heat link by Google. It wasn’t the easiest process to get it though. Plus I declined the call back as it showed as coming from a number in Romania so I thought it was a cold sales / hoax call. I now have the temporary thermostat and waiting for the engineer to reinstall the heat link.
11-01-2021 08:06 AM
Hey @Geronimo. Thanks for getting back to me. I'm happy to hear that you'll be installing a replacement. Let me know if you need my help with the installation.
11-03-2021 08:08 AM
Hello again. How's it going with your replacement?
11-05-2021 08:09 AM
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
