Temperature keeps changing
rachelZM
I have the Nest Learning Smart Wifi Thermostat purchased this past April. I have the schedules off and home/away assist off but the temperature still keeps changing. How can I set it to stay at one temperature? Please help!!
David_K
  1. Open the Google Nest app.
  2. Select your thermostat.
  3. Select the Mode option in the lower left and set the mode to Heat/Cool.
  4. Select the Eco option in the lower center and end Eco Temperatures on all thermostats.
If you also want to stop it adjusting based on home/away assist and the auto-schedule features, select the settings icon in the upper right and turn off the Home/Away Assist and Auto-Schedule options (sounds like you may already have done this).
Hello folks,
Thanks for sharing the steps, @David_K.
@rachelZM, how's it going? Have you managed to check the settings shared by davidking? Please let us know if that helps.
EmersonB
Hello everyone,
@rachelZM, we wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
I appreciate the help, Mark and davidking.
Problem solved from a knowledgeable person via call back. Thank you!
I appreciate your help, @David_K, Mark, and Emerson.
@rachelZM, thanks for the update! I'm glad to hear that the issue is now fixed. Please let us know if you still have questions or concerns. Otherwise, I'll be locking this thread after 24 hours.
