02-06-2022 07:59 AM
I want to be able to set the heating to heat based on a specific room - e.g. if I'm on nights, just the bedroom, but if I'm off, the whole house.
Is there a way of doing this? Apparently temperature sensors are only available in the US for some reason - are there any third party ones that can do it?
The best answer the Google Rep could give was that it "Should be simple enough"
02-06-2022 02:37 PM
All you have to do is when you see all your temps notice the circle by the thermostat? Touch where the sensor is and the circle will move, now the heat will be based on that sensor.
07-06-2022 12:49 PM
Hope this helps!
Kind regards,
Ryan
