Thermostat compatibility with Williams in wall gas
Riasdfasdf
@Riasdfasdf
You have a Millivolt furnace, which isn't directly compatible with any smart thermostats.
You can use any Nest thermostat, but you must also use the Google Nest Power Connector, external 24vac transformer and possibly a relay.
Try this wiring.
@Riasdfasdf
Try this wiring.
