05-23-2024 12:34 PM
Hello, Starting today my Nest Thermostat is not charging while connected to the hard wire. I followed the instructions provided on Nest Support but still doesn't work. What do I need to more to resolve this issue?
05-23-2024 03:58 PM
From what you write I believe that the thermostat was charging before and only recently stopped charging. Is that a correct assumption?
AC Cooling Wizard
05-23-2024 04:17 PM
I have this same problem, it was working for a year, now it won’t hold charge.
05-24-2024 06:51 AM
@Dpike , as long ad your system is providing power and the internal battery is no longer taking a charge, the thermostat will need to be replaced. Check your power on the Nest Thermostat display under SETTINGS. What are the values being reported?
AC Cooling Wizard
05-26-2024 02:48 PM
Battery 3.656V
VOC: 33.72 V
VIN: 31.02 V
LIN: 200 mA (c)
05-28-2024 07:43 AM - edited 05-28-2024 07:46 AM
@Dpike , based on those readings, the thermostat’s charging circuitry is working fine. Your battery is nearly fukk charge at 3.656V and charging current of 200 mA is the maximum.
if the information I provided you was of help, please tap the 👍🏻 Kudo. If my answer solved your problem, please make sure you market it as a recommended answer.
AC Cooling Wizard
05-24-2024 06:09 PM
05-26-2024 02:13 PM
Yes, I do have a C wire.
