10-06-2023 08:03 PM
i installed the Nest learning thermostat. Followed all the instructions and when putting on cooling mode it doesn’t cool, hot air comes out.
If you can help on what May cause the issue?
10-07-2023 01:06 AM
Move the white wire from the OB terminal to the W1 terminal.
10-07-2023 07:35 AM
Hi Patrick!
Thank you! I did as instructed but now thermostat wont turn on. Maybe battery died?
