Thermostat problems
Rb25
Nest thermostat says “save more at home” with a “next” button but when I hit it nothing happens. Can’t get rid of it
7 REPLIES 7
SSlott
I’m having the same issue, however the thermostat seems to be working properly otherwise…
Sunshine1665
I'm having the same issue. Started this morning. Thermostata appear to be working in the Home App
SSLi
I got the same issue this morning, 3-1-2023. on Nest Thermostat E.
NormalOne
Same here, stuck but working thru the app it seems
Hello folks,
I'm sorry for the trouble this may have caused you all. Let's see what's going on.
On your thermostat, select "Done", "Next," or "Cancel" by tapping the sensor controls on the right side of it. This will allow you to navigate it or learn how to control the thermostat manually. Check out this guide on how it works. Also, please try removing the thermostat display from its base and removing its batteries for at least 3 minutes to restart before plugging them back in.
Please let me know if that helps or if the issue still persists.
