03-19-2022 07:51 AM
My Nest thermostat is less than a year old and is displaying a temperature much lower than it actually is. Tried Reset but problem did not clear Anyone had similar issue
03-26-2022 04:03 PM
Hi CCK,
Thanks for reaching out and we're sorry for the delay.
When your HVAC unit and your thermostat is working fine, there are times that there will be a slight difference in temperature reading.
For instance, there may be a small temperature swing because your thermostat will wait to turn on your system until it gets to about 1ºF (0.5ºC) warmer or cooler than the temperature you have. This is to prevent unnecessary wear on your system and help save energy.
Check this out to know more about it.
Ryan
03-29-2022 05:01 PM
Hey CCK,
Ryan
05-28-2022 01:54 PM
Hope this helps!
Kind regards,
Ryan
