Thermostat runs pump periodically when Temperature is below freezing.
MattN330
I have an issue with pipes freezing when it is very cold outside.  I have added insulation which has helped the issue, but the best solution I found is to periodically run the circulation pump.  Is there a way that the thermostat can run the pump for x number of seconds ever x minutes when the temperature outside is below x degrees.   I would need my pump to run for about 45 seconds every 20 minutes when the temperature is below 32 degrees F for this particular zone.  The other zones I would have run less frequently if at all.
The temp in my house drops between 57 and 60 when no one is home.  This has saved a lot of energy, so I would like to see if there was a way to keep the savings and prevent the freezing issue.
I feel like this would help many people drop the temps in their houses as it would help prevent pipes from freezing.
Jeremyg
Hi @Tomwlevy!
Thank you for reaching out to the community. I understand that you want to turn on the pumps to keep the pipes from freezing. I'm glad to help you!
For now, we recommend that you take a look at this link, Heat Pump Balance.
If you have any further questions, please don’t hesitate to reply to this post. I'll be happy to assist you further!
Jeremy.
Jeremyg
Hi @MattN330!
Thanks for reaching out to the community. I am sorry that your Nest thermostat runs a pump periodically when the temperature is below freezing, but no need to worry; help is here. We appreciate all of your previous troubleshooting efforts.I need to know a few things about your thermostat in order to provide you with a better resolution.
  • What Nest thermostat model do you have? For your reference, you can check out this article on how to tell which Nest thermostat you have.
  • Does the thermostat display show any error codes or messages?
  • When did the issue first occur?
  • When was the thermostat installed?
  • What is the make and model of your HVAC equipment?
  • Do you see a blinking LED light? If so, is it red or green?
I'll be waiting for your response; any additional details you can provide will be helpful.
Jeremy.
Tomwlevy
I don’t think you understood the question. He wants to have best turn on the pumps to keep the pipes from freezing. Can nest do that?  I remember seeing a setting for that many years ago when I had the first generation
Jeremyg
Hi @Tomwlevy!
Jeremy.
