Thermostat won't work on schedule
billywhizz
My Nest heating and hot water does not work when scheduled via the app or scheduled via the wireless unit.
However, the hot water works via the Boost function and the heating when you directly turn the dial on the unit to select the temperature.
I have restarted the Heatlink (which is a new one replaced by Google) I have also restarted the App and taken property and everything off and then reconnected. The App allows you to schedule nothing comes on at the allotted time.
Is this a common issue? I haven't come across it before
2 REPLIES 2
Vladut
Hi there, thank you so much for reaching out. I'm so sorry for any inconvenience caused by this. Can you tell me how many lights are on on the Heat Link at the moment?
LarisaL
Hi there, just checking in! Did you see the message from my colleague?
