2 weeks ago
Hi
I have just got the 3rd generation pro thermostat, I am going to have the thermostat on a stand using the minI usb connection but can't find out what voltage it should be and what amps. The ones on amazon are 5v but the supply that comes from the hub would be 12v, is the USB connection just to recharge the Internal batteries or power it constantly? Needless to say I have numerous 5v chargers from phones so would one of them do?
Many than,s in advance for you help
a week ago
Hi there Charlie! It should constantly power the thermostat, not only charge the battery and then disconnect it. A phone charger as the ones you have, should do just fine.
a week ago
Hi Paul
That's what I thought but didn't trust myself enough and just wanted confirmation before doing it to be on safe side.
Many thanks
Charlie
a week ago
We're happy to help! Is there anything else I can assist you with for the moment?
Monday
Hi, just wanted to check in. Anything else I can perhaps try and assist with? If so, make sure to let me know.
Tuesday
Hi there, as you haven't replied, I'm gonna go ahead and close this thread. Let us know if you need anything else. Have a great day ahead!
