03-12-2022 02:59 AM
Will I need to reprogram my Google Nest Thermostat after I replace the batteries, and exactly what type of batteries are recommended. (I do have a power supply connected ( c wire )).
Should I use regular alkaline or rechargeable lithium?
Thank you
03-12-2022 10:50 AM
If you have the "Nest Thermostat" you should replace the batteries with alkaline.
Normally the batteries will not discharge if there is a C (common) wire or a Nest Power Connector unless power has been turned off to the HVAC unit for an extended period of time. You may want to verify C is connected at both ends - thermostat and at HVAC wiring terminal.
03-12-2022 10:50 AM
03-18-2022 12:02 AM
I appreciate your answer, sporfrog.
PeterJJ, thanks for reaching out to the Google Nest Community. I'm glad that you've got the answer to your question. Feel free to reach out again if you have more.
Melba
03-29-2022 12:01 AM
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. Should you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
