12-31-2022 06:49 AM
12-31-2022 09:46 PM
They have W (heat) jumpered to Y (AC) which is odd.
I would only use Y and set it up as a heat pump see if it works.
B should be your C (on Trane they call it B).
Red to RC
Then match up the rest the same as the old T stat.
12-31-2022 06:53 AM
Which position should these wires go on the nest!
12-31-2022 09:46 PM
Red to RC
01-01-2023 10:11 AM
Thank you
01-06-2023 02:04 PM
Brst, checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
01-10-2023 03:53 PM
Archie
01-10-2023 05:18 PM
Yes...all questions are answered.
Thankyou.
01-11-2023 11:07 AM
Hi Brst,
Sounds great! I'm glad to know that you've got the answer you're looking for. If you're still in need of assistance, feel free to let us know. Otherwise, the thread will be locked in 24 hours.
