Why is my thermostat going to high temps?
Irish44
  • Why is my nest turning my furnace on up to 89 degrees after I set the thermostat to away???
jenniffert
Hi Irish44,
Thanks for reaching out here in the community! I'm sorry to hear that the Nest thermostat is turning on your furnace to reach a temperature of 89 degrees despite being set to 'away.' I'd be happy to help!
To better investigate the inconvenience, I'd like to ask the following:
  • What is the model of your Nest thermostat? Here’s a helpful article about how to identify your thermostat model.
  • Are you using the Nest app or Google Home app?
  • Do other members of your household have phones that are attributed to the Home & Away feature, or are you the only one using it for your home?
  • Is this the first time you're experiencing this situation with Home & Away?
In the meantime, I'd suggest the following:
Please keep me posted.
Jenniffer
