08-24-2022 05:26 AM
Hi looking for advice ,
We have a BoilerMate OV system where the heating controls are conveniently in attic , can I use a Nest wireless system to control the heating and hot water which are currently controlled separately, but using the same analogue clock and separate on of switches
08-30-2022 02:22 AM
Hi there, @Alan7
Thanks for reaching out. In theory, they should be compatible. You can try checking out with our compatibility widget here: https://goo.gle/2UDR7jj
Let me know how it went please.
09-01-2022 02:27 AM
Hi there. I'm just following up on our last message. Do you still need our help? Keep us posted.
09-03-2022 03:30 AM
