07-26-2023 06:20 AM
Yellow wire constatntly says not connected. I remove it, reconnect and its fine again. This last anywhere from 3-4 hours. Switching Nests, the other one has the same problem. I'm guessing it's the base? The wiring is fine, I've chacked the other en. Disconnecting and reconnecting the AC end makes no change in problem, only fixes it when I diconnect/reconnect the the Nest end. New unit, did I get a lemon base?
07-30-2023 03:02 PM
Hi MeMedic,
Thanks for reaching out. I'm sorry for the delay. I'd like to take a closer look at it. A few questions: what type of Nest Thermostat do you have? You can visit this link to check what type of thermostat you have. What are the exact messages or codes you keep receiving? Could you please send us a photo of your thermostat wires? Also, the wires that are connected directly to your HVAC control board.
08-03-2023 11:37 AM
It's me again! I just want to check if you managed to see the response above. Please share with us the needed information, as it will help us to move forward.
