dual fuel with Y W G R O(connected to B) wires
ofreunde
nest.com/works don't provide good solution for the wiring.
There's no C connection in the old thermostats.
There are Y W G R wires
and Brown color(may be orange) wire is connected to B. while O is not connected. 
I heard that the furnace is dual fuel system.
What'd be the correct connection to Nest?
Ryan_G
Hi ofreunde,
Thanks for reaching out and we're sorry for the delay.
Based on your wiring description, you possibly have a (dual fuel) heat pump. Your system is compatible with Nest Learning Thermostat.
We could use the O or B wire as a common wire when you get it connected to the Nest Thermostat.
Let us know how it goes when you try it to connect with Nest Learning Thermostat.
Ryan
Ryan_G
Hey ofreunde,
I just wanted to follow up and see if you are still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
ofreunde
Thanks for the info. It is dual fuel system. Actually the heater was broken and I needed to call technician, and let him install the nest. After all work done I found that he didn’t connect B to anywhere. Only 4 wires are connected and it’s working. But as far as I know, nest will not get charged if heater or cooler is not working.
would it be safe to connect the brown wire to connect to C?
Ryan_G
Hey ofreunde,
Thanks for the update.
You're right that the Nest Thermostat get's a little power from your heater or cooler to keep it charged.
You could also try to connect the brown wire to the C terminal to be used as a common wire as it is only for a stable power purpose.
Let me know how it goes by replying to this thread.
Ryan
Ryan_G
Hope this helps!
Kind regards,
Ryan
