12-04-2023 10:52 AM
Nest thermostat is a couple years old, doing some remodeling and turned off heat, the battery died on thermostat, I turned off breaker at main panel,charged using usb cable, and adapter and now get e73 message. Safety switches are clear and no water in them. Got power to unit but not to thermostat
12-07-2023 02:53 PM
Hi Jmicheal11,
Yikes! I'm sorry to hear that your thermostat is giving you E73 error code. Let's see what's going on. A few questions:
Also, check on the following (take note to turn off the power breakers before touching any wire on the thermostat):
Keep us posted. We're happy to help.
