hot water icon not present on thermostat
balajis4u
Hi, I don't see hot water icon on thermostat 3rd gen. not sure wired correctly for hot water. any help much appreciated.
thanks Bala
Frustratedddd
I think you may have missed part of the setup.
Go into settings - Equipment - Pro Setup - System Boiler
Follow the instructions, and when you get to On/Off - Not Connected make sure you are set to ''On/Off
That should sort it out.
