10-30-2021 04:22 AM
I have a single zone hot water heating system fired by a weill mcclain gas fired boiler with a pump
The controller is a Tekmar 256 with outdoor sensor. It seems to have a R T and C wires labelled and the others are just for sensors
The wiring manual for the Tekmar has this picture
https://www.manualslib.com/manual/1713395/Watts-Tekmar-256.html
How do i put the nest here?
12-22-2021 11:20 AM
Hey ulall,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
12-22-2021 11:57 AM
yes - still curious as to teh best way to do this
12-28-2021 02:06 PM
Hey ulall,
Reviewing the post and wiring diagram you had sent, I would recommend having a Nest Pro come out and take a closer look. Each system can be a little different, and it's best to have someone in person to review and ensure the device is set up correctly. I understand that this is not the most ideal answer, but I would not want to cause damage to your system if something is installed incorrectly.
01-03-2022 10:37 AM
Hey ulall,
Please let me know if have any other questions from here, as I will be locking the thread in 24 hours due to inactivity.
01-04-2022 11:00 AM
Hey ulall,
It has been a few days since the last reply, and I am going to lock the thread at this time. If you have any questions, please feel free to create a new post.
