01-25-2024 02:38 AM
How do I properly set up the Nest thermostat for use with a hybrid heat pump and the correct configurations? We have a gas combi-boiler and a heat pump, but I can only choose between a heat pump and no hybrid heat pump.
01-31-2024 02:41 PM
Hi Rienez,
When setting up a Nest thermostat for use with a hybrid heat pump system that includes a gas combi-boiler, you'll need to configure it correctly to ensure optimal performance and efficiency. If you have a hybrid heat pump system, you will need to have a trained professional or local HVAC professional to set up your thermostat. It’s important for a professional to assess the requirements for your specific hybrid heat pump configuration since choosing incorrect options for a dual fuel system can result in damage to your system. Learn more here in the Nest thermostat compatibility article.
Let us know if that helps.
