08-04-2022 09:11 AM
Sensor went offline after one month of working fine. deleted sensor device but cannot how to add back as google nest and google home app doesnt find. swapped battery, no change.
08-10-2022 11:45 PM
Hey psconway,
Thanks for posting and I'm sorry to hear about your Nest Temperature Sensor.
Just to confirm, did you take off the sensor from your Nest app? If yes, you need to redo the setup by following the steps here: https://goo.gle/3dpEILK If you're running into some difficulties completing the setup process, try the troubleshooting guide here.
Keep me posted.
Melba
08-14-2022 02:27 AM
Hey everyone,
I'd like to jump in here and check if you've seen Melba's response. Let us know if you need more help by replying to this thread.
Thank you for your help, Melba.
Ryan
08-16-2022 12:00 AM
Melba
