10-01-2024 04:57 PM
installed nest thermostat back in April has been working fine and just now lost power. have reset Hvac, taken batteries out and put back in, checked all wiring taking wires out putting back in, no blown fuses , no issues with unit and water drain pipes etc
10-01-2024 07:15 PM
I have the exact same issue. Just started last night and we have no ability to adjust AC
10-04-2024 11:19 PM
Hi there!
Thanks for posting in the community.
I’m sorry for the inconvenience that you’ve been experiencing with your Nest thermostat. I understand that you just installed it some months ago and it was working really well, then it just started to lose power. You have already tried some troubleshooting steps but still have the same issue. No worries, help is here.
In order to give you the correct steps I need some extra information. Here are some questions for you:
In the meantime, please try to change the batteries for some new batteries following the next steps;
Note: We recommend you use Energizer AAA 1.5 V Alkaline batteries.
In the meantime, you can check the following articles for further information: Change Nest Thermostat batteries (Low battery message) and Troubleshoot when your thermostat won’t turn on.
I will be waiting for your response.
Daniel.
