Certain Websites will not load
Waldo24
Certain websites will not load across my home network. There are some big-name company pages that won't load, but there are also local companies that won't load up either. I originally thought that it was just the computer, then I tried a different PC. Then I tried a phone, still nothing. I then thought maybe it's my browser, tried chrome, safari, and firefox, still absolutely not working. I then disconnected from Wifi and used my 5G hotspot from my phone, and it worked. So I have learned that these pages such as Netflix, and then some local company pages will not work on Nest Wifi for me. This is weird because I have been using Nest for 2-3 years and this issue has never come up. I have unplugged from the internet entry. I have restarted the Nest Wifi. The only thing I haven't done is resetting the Nest for sake of not wanting to set every single device back up on my home network. Any help would be great.
6 REPLIES 6
Waldo24
I Factory reset, no fix
EdwardT
@olavrb and Tuzza, thanks for the help!
@Waldo24, how's it going with your Google Wifi? Still need our help?
Edward
EdwardT
Hi Waldo24,
I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Edward
EdwardT
Hi Waldo24,
Edward
Tuzza
Might be a stupid question, but you’ve not got any parental control settings on your modem or ISP have you.
olavrb
Does it work if you connect a computer to your modem with an ethernet cable directly, bypassing the Nest Wifi?
History from previous topics about similar issues:
One thing to try is to disable IPv6 in Google Home, wait a bit, then enable it again.
I don't work for Google.
