03-20-2022 01:11 PM
I have the original 2016 Gen 1 model google WiFi mesh router. A single unit. I live in a 2 story concrete home. WiFi router on ground floor. Upper floor has WiFi connectivity issues.
Can I buy a 2nd google WiFi mesh router to connect to 1st mesh router using LAN cables instead of WiFi? Or both routers can only be connected via WiFi?
Thanks for any response!
03-21-2022 07:16 AM
Hello @TM3SRP
Yes – you can connect a secondary Google WiFi unit on the upper floor to the LAN Ethernet port on the primary Google WiFi unit on the ground floor. This is highly recommended in a concrete home, especially if it also has concrete floors. Here's a more detailed support article: https://support.google.com/googlenest/answer/7215624?hl=en
03-21-2022 11:29 AM
That's good to know. Yes, the floors are concrete. Thank you for the response as well.
Have a good one!
03-21-2022 07:16 AM
Hello @TM3SRP
03-21-2022 11:29 AM
Have a good one!
03-24-2022 10:25 AM
Hi, TM3SRP.
It looks like MichaelP was able to help you out on this one. I just wanted to check in and see if you had all the info you needed or to see if you needed anything else. If you're still looking for some support, just let me know.
Thanks.
03-24-2022 11:46 AM
Thanks Jeff. Works great! thanks for the follow up.
03-24-2022 02:39 PM
Ah, that's great news TM3SRP. Thanks for letting us know. I'll go ahead and mark this as resolved, but if you need anything else at all, please go ahead and open up a new discussion.
Thanks!
