Google WiFi speed issue
avnsss
I use a 200Mbps connection at home. After configuring Google WiFi the speed dropped down to 90Mbps max. Where I can achieve full speed on my ISP provided router.
Help me in this regard.
7 REPLIES 7
EdwardT
Hi avnsss,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Google Wifi. I'd love to know more about this and I have a few questions:
  • Could you try doing a speed test while connected directly to your ISP modem?
  • Are there any nearby devices that would cause interference?
  • How many Google Wifi points do you have?
Edward
avnsss
Hi Edward!
Thanks for your reply. Now I am having 4 WiFi points configured(including the master). When done the speed test connected to ISP modem, it shows full speed of 215 Mbps everytime when I tested. There are no any other devices that would interfere with the router signal.
Thank you once again Edward! Looking forward to hearing from you.
EdwardT
Hi avnsss,
Thanks for the response. Is your ISP router also broadcasting a Wi-Fi signal? If so, I would suggest setting it to bridge mode. You can click on this link to learn more about this.
Edward
avnsss
Hi Edward!
Yes, my ISP provided router do broadcast a WiFi signal.
Will try with the bridge mode and get back to you.
EdwardT
Hi avnsss,
Thanks for letting us know. Were you able to try bridging your Google Wifi? Keep us posted.
Edward
Jeff
Hi avnsss,
I just wanted to jump in real fast to see if you saw Edward's latest reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
Jeff
Jeff
