04-07-2022 05:13 PM
How do I set up smart devices when the following are true:
1: Google combines 2.4 and 5 ghz wifi into a single network name (and doesn't appear to let you distinguish between the two).
2: You need to be on 2.4 ghz to set up most smart devices.
3: iOS does not let you select which band to connect to.
Is there any way to set up smart devices using google wifi and an iPhone? This feels like a major oversight.
04-07-2022 11:19 PM
It is an oversight...on behalf of the 'smart' device manufacturer! They should have built their app smart enough to figure this out.
BUT..given Google chose to combine the frequencies to keep things simple, you're stuck...you could try connecting up an old router temporarily, one that allows you to broadcast only on 2.4ghz....give it the same Wifi name/password as your Google wifi, so when you switch back the device will connect up ok.
Another choice would be to find an area far enough away from your wifi signal so that only 2.4ghz is being received in that area, set the device up there...but it's very hit and miss.
04-11-2022 09:29 AM
Hi, excited2behere.
I just wanted to jump in real fast to see if you saw Juzdu's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
04-29-2022 10:24 AM
Hey, excited2behere.
I'm just following up once more to see if you still needed some help here. If there's more we can do, just let us know.
Thanks.
05-03-2022 10:09 AM
@Juzdu and @Jeffrey, thanks for the help!
@excited2behere, Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
