10-30-2023 12:44 PM
The Nest PRO WiFi is slowing my internet speed by 2/3 of the speed my modem recieving. I do have latest software update, however, it did not help.
What or when the issue will be fixed?
11-01-2023 07:52 PM
There seems to be a few threads with similar slow wifi speeds vs the main ISP router wifi... It shouldnt be dramatically sower.
Hope that the GOOGLE pros chime in and provide some guidance.
11-08-2023 09:39 AM
Hi MartinKiraga1,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? What device are you using to set up your network (iOS or Android)? Do you have the Internet from your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Thanks for helping, AdamRFX!
Dan
