10-31-2022 12:12 PM
Does the Google Nest WiFi Pro works in Israel?
Will I have any issues setting it up or activating it?
10-31-2022 01:22 PM
You'll probably have no problems, but Israel is currently not on the list of supported countries:
Which matter mostly because of differences in Wi-Fi/ wireless signal regulations (signal strength and frequencies). Take this list for instance, which shows differences in 5ghz Wi-Fi:
Worst case the equipment you buy might not even be legal to use in Israel, see this for instance:
TLDR: Will likely work, will might not be strictly legal, and your milage may vary.
10-31-2022 01:22 PM
11-04-2022 08:33 AM
Hi @olavrb ,
Thank you very much for the detailed response.
If I read the WiKi page correctly, it shows that Israel and the US are very similar in what is allowed to use Indoors. Meaning, in Israel everything is restricted to indoors, while in the US it is not, but besides that difference, the frequencies and the like are very similar (besides some specific UNI-4 channels.
As such, I am less concerned about the legal stuff, was more worried about general compatibility with devices and freqeuncy.
The best example is FM radio, in Israel they use 88.00-~108.00 while all values are valid 99.5, while in the US it is only negative or positive (can't remember).
In any case, thank you very much, this is very helpful.
11-04-2022 08:10 AM
Thanks, @olavrb for the info.
Hi aviramido,
I just wanted to jump in real fast to see if you saw olavrb's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
11-04-2022 08:33 AM
Thanks for following up, the answer did help greatly.
11-04-2022 08:41 AM
I'm happy to hear olavrb's input helped out, aviramido.
Before we mark this as resolved, is there anything else you might need?
Jeff
11-04-2022 09:02 AM
Not at the moment, thanks!
11-04-2022 01:10 PM
Sounds good, aviramido. If you need anything else down the line, just let us know. I'll mark this one as resolved for now. Thanks again to olavrb for the help!
Jeff
