04-06-2023 07:59 AM
I have spent hours researching, with tech support, made a previous post here( https://www.googlenestcommunity.com/t5/Nest-Wifi/Nest-wifi-pro-slow-speeds/m-p/375956#M40222 )
the big November update that was supposed to fix everything did nothing, there have been no solutions, I was given a form to fill out and promised someone would contact me. Only so they could close out my post. Which is now locked. Of course, no one has contacted me. The Nest Wifi Pro is not performing the way it should or was advertised. Especially for the cost. Google has not offered anything to correct this issue. Being a Google fan this is extremely disappointing. Is it too late for a refund? I don't even want it anymore. What business is ok with putting out a product that is failing so bad.
04-06-2023 04:24 PM
I just purchased it and set it up. and am getting significantly slower speeds than my Google Wi-Fi points...I'm extremely confused on what to do. Sounds like I should just go ahead and return it?
04-06-2023 04:29 PM - edited 04-06-2023 04:30 PM
Yes, exactly what happened to me. Google wifi was great. Thought the "Pro" would be an upgrade, not a major downgrade
04-06-2023 05:10 PM
I'm still not getting the same speed at my router but i am now finally getting better speeds overall. It might have something to do how it installs. I'll keep monitoring and hope that someone comes on with a real answer for why my 1 GBPS service is only showing up as 500 MBPS connected by a CAT cable
04-09-2023 07:52 PM
Hello everyone,
@RobHughes, thanks for posting. I’ve checked your case and saw that our senior specialist sent you an email. Kindly search your inbox for an email with this subject head: “Your Google Support Inquiry: Case ID [6-2284000033884]”.
@ZJS, I’m happy to hear that your issue has improved. What kind of Ethernet cable are you using? I’ll wait for your update.
Abi
04-10-2023 01:07 PM
I'm using the cable provided for the Google WiFi
04-10-2023 07:24 PM
Hi ZJS,
I see. Let’s keep monitoring your speeds for now. If anything changes, reply to this thread and let us know. I’ll keep it open for a few more days for you.
Abi
04-11-2023 02:28 AM
Still getting 500-600 MBPS at the Google WiFi pro connected to the modem.
04-12-2023 06:30 AM
Also one of my points that was "great mesh connection" is now weak and literally nothing changed. This is very frustrating.
04-12-2023 04:12 PM
I went ahead and bought a new Cat 6 cable and moved my WiFi pro attached to my modem closer. I'm getting a weak mesh connection and I can't be more than 25 ft away. If I move any closer I'll basically be in the same room. This can't be the intent. It says it covers 2500 sq ft each point. My house is only 1700 sg ft and I have 3 points. What am I missing here?
04-12-2023 07:36 PM
Hey ZJS,
A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Also, do you have any paused devices?
Give these steps a try:
Since you mentioned that you’re using 3 Nest Wifi Pro router and points for your 1700 sq ft home, I also suggest keeping just the main Nest Wifi Pro router as one device can already cover up to 2200 sq ft. Having more than what is needed could potentially cause interference if the coverage overlaps. Check if your speed improves after doing that. Let us know how it goes.
Abi
04-15-2023 07:50 PM
It's me again. Just checking in if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions ― we'd love to help.
Abi
04-16-2023 08:31 PM
Hello everyone,
Abi
04-17-2023 04:10 AM
Hi Abi
I replied yesterday but failed to post.
Im still having a speed problem at the modem to router connection. Its just a modem only. I factory reset, switched to a different Pro router and am still only getting around 600 MBPS. With my computer I am getting 950 MBPS. I understand the Pro router is designed for 1 GBPS. Please advise on other options to remedy
04-18-2023 09:56 PM
Hi again ZJS,
I'm sorry to hear that you're still having an issue with your Nest Wifi Pro. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Abi
04-22-2023 10:16 AM
Hello everyone,
@ZJS, we got your form! Please bear with us, as our specialist team will reach out to you to assist you further.
@RobHughes, I just want to follow up with you. If you are still having issues, please fill out the form above.
Lovely
04-25-2023 12:42 PM
Hey RobHughes,
Checking in again — did you happen to get that form filled out? Let me know if you have questions about it.
Lovely
04-28-2023 01:37 PM
Hi RobHughes,
I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we close this thread in 24 hours.
Kind regards,
Lovely
