04-05-2022 09:45 AM
I'm trying to help my brother port forward for a minecraft server and am mostly aware of how to set up port forwarding rules. The problem is that neither of his pc's ipv4 addresses are found in the device list. I know that he's connected to the right network via ethernet. One of the devices is eerily similar to his ip but off slightly... for example a "135" where there should be a "35", with the rest identical. Does anyone have any guidance or suggestions? And a related question, in the last rule section of port selections, should I input a single port as "25565" or a range of 25565 to 25565?
Thanks
04-06-2022 01:53 PM
For reliable port forwarding, make sure the device does not randomize its MAC address. And set a static IP by DHCP reservation:
Then port forward:
If you still can't see it, maybe there is an additional NAT router in between?
04-08-2022 12:10 AM
After setting a static ip on the router and PC it does show up under the device list, but after several port forwarding attempts I’m still unsuccessful. I believe I’m dealing with a double NAT from our modem, which should be an easy enough fix. Thanks for your help.
04-10-2022 11:03 AM
@olavrb, thanks for the help!
@thatonealexgu, how's it going with your Google Wi-Fi? Were you able to bridge your router to fix the double NAT issue?
Edward
04-13-2022 04:01 PM
Hi thatonealexgu,
It's me again, I wanted to check back in to see if you have other questions and concerns. Feel free to let me know if you do.
Edward
04-15-2022 09:08 AM
Hi, everyone.
Thanks.
04-17-2022 10:49 AM
Since we have not received any more replies for quite some time, I will lock this thread now. Please feel free to create a new thread should you have some more questions or concerns in the near future and we'll be more than glad to help.
Edward
