11-08-2023 06:11 PM
I am completely stumped. I have a Nest WiFi model HD2. Today we disconnected our cable service and had Fiber Internet started with a local provider. Yayyy for getting rid of Comcast/Xfinity.
The local fiber is FAST. When I run speed checks in the main part of the house, I'm getting speeds over Mbs Up and Down. Everything on the main router seems awesome.
The WiFi point on the other end of the house is super slow. A laptop sitting right next to it is reading D/L speeds in the teens. U/L almost non existent. Tested with multiple wireless devices.
When I test network performance on the Home app, it says Speeds at the router are almost 1,000 Mb down and over 800 Mb up. When I ask the system to test the mesh, it comes back mesh connection as absolutely great, no problem.
We've tested it with phones and laptops. Same results, all devices.
So, like I said, I'm stumped.
11-13-2023 09:43 AM
Hi Bill1071,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? What device are you using to set up your network (iOS or Android)? Do you have the Internet from your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
