10-29-2022 07:26 PM
I just purchased the three pack of the NestWi-Fi pro. Each unit is supposed to be capable of being either a router or a point. The first unit I set up as a router onto my network fairly easily. But when I try to add the other units as points the Google app continues to only recognize them as routers and I am unable to connect them to the mesh. The App wants to connect to their broadcasting Wi-Fi but then indicates there is no connection to the Internet.
10-29-2022 08:42 PM
I purchased a Pack of 3 and a Pack of 2 Nest WiFi Pro. Everything work good until i tried to hook up the 5th unit and I keeps stating I am too far from the router. I'm 3 feet from it. It says you can connect 5 nodes. Apparently not. I factory reset it and tried over and over again. All my WiFi points say Weak connection in a 3,450 sq ft one story home. I feel your pain. No online help and no phone number to call. Looks like I have one unit that's a dud.
11-02-2022 10:51 AM
Thanks for letting us know ― let's see what happening.
A quick question: are you selecting the home during the setup process where your main Google Nest Wifi Pro router is set up?
Give these steps a try:
Keep us posted.
Mel
11-05-2022 12:58 PM
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
11-06-2022 12:21 PM
Mel
