10-10-2025 02:35 AM
Kids factory reset my wifi point - I am trying to reconnect it - Go through all the stages point shows blue ring colour, first notice i get is that the wifi point was manufactured for another country, but allows me to progress to connect, Then I get a notification that 'Could not communicate with your Wifi Point'
Tried a couple of times with no success. What should I do?
10-10-2025 02:48 AM
Found the code, got the magnifying and LED lighting out - That needs to be clearer.
10-13-2025 04:42 PM - edited 10-13-2025 05:25 PM
Hi @JustLooking,
Thank you for reaching out to the Google Nest Community. I understand that you are trying to reconnect your Nest WiFi point after an accidental Factory Reset, but you're getting a "Could not communicate with your WiFi Point" error. I'm happy to assist you.
I appreciate you informing me that you found the code, but to get a better handle on where things stand: Did you successfully add the Nest WiFi point back into the Google Home app after the reset?
Gabriela
