06-05-2022 10:32 PM
Bought the 3 pack of Wifi points. Two are working and the other turned solid blue. Tried the factory reset by holding the reset button, plugging in the power, and waiting until it’s flashing blue. It flashes blue indefinitely. When I unplug and plug back in, it’s solid blue indefinitely.
please help
06-06-2022 02:57 PM
How long have you tried to wait? It can take up to 10 minutes, the guidance says.
06-06-2022 10:28 PM
I let it blink for 10 hours.
06-07-2022 07:09 AM
If it's the Google Wifi gen 1 you got, then pulsing blue means it's ready for adoption, according to the first link I sent.
06-07-2022 07:39 AM
I appreciate your help. But it’s not the pulsing blue, it’s a fast flash. It will not connect.
06-07-2022 03:00 PM - edited 06-07-2022 03:00 PM
Don't know what flashing blue indicates, so I escalated the issue.
06-08-2022 10:03 AM
@olavrb, thanks for the help!
@Switchstance22, thanks for reaching out. I'm sorry to hear that you're having an issue with setting up your Google Wifi point. The light status that you're getting is unusual and we'd like to take a closer look. Please fill out this form so we could investigate further.
Edward
06-11-2022 10:51 AM
Hi Switchstance22,
It's me again. I wanted to check back in to see if you have other questions and concerns. Were you able to fill out the form?
Edward
06-12-2022 11:11 AM
Hi Switchstance22,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
