06-25-2022 01:35 PM
I am stumped with one wifi nest point that stubbornly won't move from offline. Have tried to reset the modem and Google router, moved the point to within 10 feet of the router in case there was a distance problem, etc. but it continues to show a solid blue color and indication of "offline". Any suggestions how to fix this?
06-27-2022 10:08 AM
If it's the Google Wifi we're talking about here, solid blue means it's factory resetting itself, and that it can take up to 10 minutes to finish.
What specific device are we talking about here?
How long have you waited before pulling its power chord?
06-28-2022 07:49 PM
It's a Google WiFi point that was bought in a 3-pc set. I've had it plugged in for hours without any change in the color - solid blue.
07-02-2022 02:30 PM
@olavrb, thanks for the help!
@rbmonnat, thanks for reaching out and I'm sorry to hear that you're having an issue with one of your points. I'd love to know more about this. Does the light of the point change when you hold down the reset button for 10 seconds?
Edward
07-03-2022 05:16 PM
Thanks Edward for reaching out. I have tried the reset button and waited for the point to reset, which it appears to be doing. In the end, unfortunately, it returns to a solid blue light and can't be found when I conduct a mesh test.
07-04-2022 09:07 AM
Hi rbmonnat,
Thanks for the update. We'd like to know more about this. Please fill out this form so we could investigate further.
Edward
07-10-2022 11:04 AM
Hi rbmonnat,
Just checking back in. Were you able to fill out the form? Let us know if you have questions and we'd be glad to assist.
Edward
07-11-2022 11:32 AM
Hi rbmonnat,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
