01-28-2023 08:33 AM
Yale Lock will not connect to Connect. Have tried a) resetting Connect, b) resetting Yale Lock, c) 4 different plug locations, d) New Home in Nest app, e) connecting through 2.4 Wi-Fi, f) bypassing the qr scan and manually entering code. Absolutely nothing allows these items to connect. Regretting this purchase unless you can help
01-28-2023 12:19 PM
BTW, I have Google Fiber internet and mesh Wi-Fi. You would think that of all routers there would be no problem with this one. But no.
01-31-2023 06:52 PM
UTFrus64m, checking in — I just wanted to make sure if you’ve seen User8675309’s response. Let me know if you still need help.
I appreciate the help, User8675309.
02-04-2023 01:31 PM
Hello Jan Thaddeus, Tried the suggestion below but still no connection. The Connect is only five feet away and it pulses during the process, but still fails to connect.
01-31-2023 10:38 AM
Did you reset by taking batteries out and putting back in? Or did you take batteries out hold reset button on back (while still plugged into keypad) and out batteries back in while you wait for chimes and resetting notification?
I just had to do this as I changed my wifi name.
02-04-2023 01:30 PM
I attempted to do what you recommended, but not sure what ‘while still plugged into keypad’ is referring to. Still no connection.
02-04-2023 01:42 PM - edited 02-04-2023 01:43 PM
When you take the two screws out behind batteries, you can detach the housing, there is a wire that connects through the door to the keypad if your remember when you assembled and installed it (if you didn't install watch a YouTube video on installing it).
02-04-2023 02:10 PM
I didn’t install this as it is a new door and door guy installed the lock. Are you suggesting disconnecting the wire and reconnecting?
02-04-2023 02:20 PM
No.
I'm saying make sure to not disconnect the wire while trying to press the reset button, also you need to put batteries back in while pressing reset button. I think it's like 10 or 20 seconds until the factory reset chimes happen.
Good luck!
02-06-2023 08:05 PM
Hey all,
@UTFrus64, how’s it going? Were you able to try the steps shared by User8675309?
@User8675309, thanks for your continued assistance.
@Lighthearted, I appreciate your efforts here. Let’s further check this.
You can also give these steps a try:
Let me know how it goes.
02-11-2023 02:14 PM
Hello. I’ve been out of town but back on the job today to try to get this connected
02-11-2023 02:27 PM
So here is the latest. I have google fiber and I would think setting up a nest product would be easy and fast. Not so. I set my phone to my 2.4 network. I start over with a new setup on my nest Connect. It sees my network but will not connect to it. “Something Went Wrong”
I am going to verify that password now. This is such a nightmare, it’s hard to believe.
02-11-2023 03:23 PM
Final update. I started over again from scratch. Probably the 20th time I have done this. Deleted Connect and added again. Linked to my home Wi-Fi. Tried to link the Nest lock to the Connect. It connected. WTF!
02-11-2023 10:59 PM
UTFrus64, woohoo, sounds good! We appreciate your efforts here. Give us a shout if you need anything else.
Lighthearted, checking back in — how’s it going? I shared some steps above that should help do the trick. Those should help you get back on track.
Thanks for chiming in, Brad.
02-15-2023 01:49 PM
Hello Lighthearted,
02-17-2023 03:52 PM
Hello there,
I appreciate the help, JT and Brad.
Archie
02-10-2023 09:13 AM
02-05-2023 02:11 PM
I’ve reset it 20 times and it cannot find this lock T026 code. I was able to reset and reinstall another lock in the house without issue.
it says I should press the button on the inside of the door and it will say ready. That’s what it did for the other lock. This lock just clicks several times.
