Need a hex key for my nest cam with floodlight
DeeAnn628
My 8 week old camera is defective and Google will replace it. However, Google can’t or won’t replace it without the serial number. I had an electrician install it and I don’t have the box, the serial number or the hex key so Google can initiate the replacement process. The device is located above garage door making this process of removing it so I can find the serial number challenging. I did all the troubleshooting including removing the device from the app so I don’t have that option. I appreciate any assistance. Thank you
@DeeAnn628
Do you have any Allen wrenches that might fit?
Like these at Home Depot?
https://www.homedepot.com/p/Husky-Short-Arm-Hex-Key-Set-Metric-10-Piece-HSAHKM10PCN-06/317213890
Thank you for your assistance. The 2.5 mm Allen wrench worked. Thank you for your time.
janthadeus
Checking in — I just wanted to make sure if you’ve seen MplsCustomer’s response. Let me know if you need anything else.
The 2.5 mm Allen wrench worked. Thanks for following up.
janthadeus
Hey DeeAnn628,
Awesome, glad to hear! As we got our resolution here, I'm going to mark this thread as complete. I'll be locking this thread if we won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
