07-24-2023 12:10 PM
I have a new YRD540 Nest/Yale lock.
First, I couldn't get the Nest Connect to connect to our home's new TP-Link Mesh Wifi using the app. Signal was great. 1 foot from the router. Tried different sockets/locations. Even reset the Connect. Keeps looping saying "There was a problem, couldn't connect."
So, I moved the Nest Connect to be within the range of our TP-Link Mesh extender (WIFI name ending in EXT). This is in a part of the house were I cannot actually use the device, but I wanted to see if it could connect to a different wifi network. Within moments, it connected successfully.
Then I took the Next Connect to its needed location (beyond the reach of the EXT wifi), but because it was already part of the EXT network I could not reconnect it to the original wifi. I therefore "removed the device from my home" using the app AND I did a factory reset of the Nest Connect to get the yellow light.
Now, when I try to start from scratch in the proper location, once I scan the bar code in the app, it jumps to asking me where in the house it will go (it still remembers the barcode/device even though it was removed from the app). So I tell it where, and then the app prompts me to run the connectivity test with the device unplugged. Of course, there is no connection, and I end up in another perpetual loop.
Pls help 🙂
08-07-2023 06:06 PM
Hi mdbk77,
I apologize for the delayed response and for the issues you are having with Nest Connect. No worries; I’m here to help. Let's take a look.
A few questions: are you using an iOS or Android device? How far is the Nest Connect from the router? Do you have any other devices that experience issues with Wi-Fi? Also, are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the device you want to pair? Those devices could interfere with the Wi-Fi or Bluetooth signal.
Let’s try the troubleshooting steps below.
More information here: Set up Nest Connect.
Lance
08-09-2023 07:45 AM
Hi Lance!
Better late than never! I’m no longer in Mexico, but when I return in December(!) I will follow these steps 😁
08-09-2023 12:27 PM
Hey mdbk77,
Sounds like a plan! Let me know then if the steps above work.
Lance
