Can't use Gemini on my nest audio
Luddan
Hi, I saw a post that you can now use Gemini on nest audio..
I can't use Gemini on my nest audio for some reason?
Suc_dpe
Solutions Expert
Solutions Expert
Gemini support on Nest Audio is rolling out gradually. If you can't access it yet, it's likely not available in your region or account yet.
Check these:
  • Make sure your Google Home app is updated
  • Verify your device language/region settings match where Gemini is supported
  • Check if your Google account has Gemini access enabled
If settings look correct: The rollout is still in progress, so you may just need to wait. There's no manual opt-in - it should appear automatically in your assistant settings once available for your device and account.
Try checking the Google Assistant settings in your Home app to see if Gemini appears as an option.
2 REPLIES 2
Suc_dpe
Solutions Expert
Solutions Expert
Check these:
marcolopes
I've seen the latest NEWS following the Google Home APP "Gemini is coming soon..." and now it's clear!!!
Only available (for now) on the USA with a $10 MONTLHY subscription!!!
Sure... Are you going to apply those values to EUROPE??? Nonsense! We don't make 100.000 a YEAR!
So... no plans to give access to Gemini through the NEST Speakers of existing users with no subscription??
Are we stuck with obsolete, NON WORKING devices, full of BUG and problems, that don't even work with the most BASIC tasks??
