04-19-2022 02:26 PM - edited 04-22-2022 04:46 PM
If I want to change temperature of light, I only say the color name? Can I say make light warmer or whiter?
Solved! Go to Solution.
04-19-2022 11:54 PM
As you can see Examples for the ColorSetting trait, it only supports a command to set the absolute color value.
"Make light warmer (or whiter)" probably is an utterance to trigger relative commands, currently not supported.
To change the temperature of light, you can try either sample utterances or an alternative one which makes sense to you even if the document doesn’t cover it.
04-19-2022 11:54 PM
